Hi Everyone, a few days ago I started noticing a weird colored ring around the bottom drains. What caught my eye was that half of the circumference is dark blue and the other half is yellowish and both drains have the same appearance in the same direction. As background, my pool was experiencing high chlorine for a few days (10ppm), due to a combination of tricolor tablets and SWG cell (cell was going bad). PH and alkalinity have been in range but calcium hardness very low. I drained some of the water and refilled using hose-water to lower the chlorine We had a series of rainstorms that week as well. Not sure if any of this is a contributor. I read online that discoloration can happen when there are too many minerals present in the water. Before I head down that path, figured I'd get the experts to way in.
Btw - Chlorine is still high (~10ppm), PH is 7.8 and Alkalinity is 80. I've just added Chloru-Neutralizer from Leslie's and shut off the cell (got a new one) until it comes down in range. I have a gunite/plaster pool. Any thoughts on what's causing the discoloration and how I can prevent and restore it would be greatly appreciated.
Below is a picture of the drain.
