- Feb 6, 2018
- 184
- Vinyl
- Hayward Aqua Rite (T-15)
Looking at the stabilizer scale of the Taylor 2006 test kit, the ppm markers for the 60-100ppm range are very close together. I recently made a stabilizer add to the pool. It seems to only take several drops to go from 90 to 80 and depending on who reads it, I'm getting answers of 90+ down to 75 (yes, I'm very familiar with exactly how to prep and read this test).
I was looking at the ppm markers for the 30-50ppm range which are very far apart making it easier to target your exact value (probably why my neighbors who use the standard advice of 30-50ppm never complain that the test is difficult). So in that 30-50ppm range several drops difference isn't going to change your result much at all. My question is, if I PROPERLY dilute my pool sample with tap water in an EXACTLY 50:50 ratio, can't I perform the CYA test as usual then multiply by 2? Wouldn't that give an OVERALL more accurate result being that I would now be reading in that expanded band? BTW - I'm talking about using this dilution method when stabilizer levels are 60+ppm of course. Thanks!!
