Digital pool tester
May 29, 2018
155
Bluffton, Ohio
Fiberglass
CircuPool RJ-30 Plus
Being colorblind, I have always had to have my wife help read strips from Baquacil when I didn't want an hour round trip to the store. The last couple seasons I had used Lamotte digital system and was decent. I know they also have systems for chlorine too. Is there any other brands they may work better? I am not able to use any of the color-based systems on my own without guessing which I do not want to do.
Have you tried the Taylor FAS-DPD test? It’s a drop test. It turns red in the presence of chlorine, you count the number of drops needed to turn clear. Can you see the difference between red and clear?
I haven't purchased any tester for chlorine. A buddy suggested aquchek truetest didgital, which I may pick up as a starter. Yes I can see red. I'm green/brown deficient but I surely do know what algae looks like!
Just get the Taylor FAS-DPD test then.
If all you have is the color q, you need a CYA test kit too. Not sure if CH is a concern in your area, but we know the color q does not provide accurate results for CH.
At the end of the day, an entire drop based test kit is probably worth it.
This is the unit I have purchased. ColorQ 2x
It handles the following:
Free Chlorine (DPD)0-10 ppm100
Total Chlorine (DPD)0-10 ppm100
Bromine (DPD) - uses the Chlorine (DPD) reagent set0-22 ppm100
pH6.5-8.5100
Total Alkalinity0-300 ppm100
Calcium Hardness0-600 ppm100
Cyanuric Acid0-150 ppm100
If it doesn't do well enough, I will have to resort to my namesake... Taylor system....bundle with the whale brush I do miss having one!
