Dig day, and i think they hit and cracked sewage pipe
usfbull
217
Tampa FL
I spoke with one of the workers and he told me they will repair the pipe. It is in the corner in the shallow end.
Does the pipe need to be re-routed? I am waiting to hear back from the PM but the worker made it seem like they will repair and have it run at bottom of pool.
  • Wow
Reactions: Nikilyn
zea3
12,871
Houston, Texas
I would think they would have to re-route the pipe. You can't bury it under the pool, and the line needs to be at a specific slope and drop to drain properly. Its not a pressurized line that will flow uphill unassisted. Paper and waste will cause the line to back up if they drop it down and raise it back up to connect into the rest of the sewage line. Didn't they have someone mark the utilities in the yard before the dig started?
Reactions: usfbull
usfbull
217
Tampa FL
Thanks, his response was "they will repair the pipe and form around it". He said they would go straight through the pool shell. "Will need to get a plumber to reroute around corner of the pool"
I followed up by inquiring about them having checked on and marked all utilities prior to digging. I dont see how they could run it through the shell when the pipe is maybe 2 feet below the surface and I asked if they will be sending out a plumber.
ajw22
23,630
Northern NJ
Pentair Intellichlor IC-60
You need to halt the build and get your own plumber to reroute and fix the waste line properly. I would not want that line buried in or under the pool and would not trust that the plumber they send does it properly.
usfbull
217
Tampa FL
The digging was completed. That corner where they hit the pipe was the last section they had left to dig. They need to at least try and repair it temporarily as it is a holiday and I doubt any plumber is coming today or tomorrow.
ajw22
23,630
Northern NJ
There are plumbers who do emergency 24hour a day call outs.
A temporary fix can be done with the right pipe from HD.
Reactions: usfbull
usfbull
217
Tampa FL
Yes, they plan to do the temp fix today. Next week they will have a plumber out to reroute around the outside of the pool.
