So my salt cell is dying I believe because 2 independent tests showed a salt level of 3000 and my chlorine generator says I only have 2200 sometimes and will stop generating. My water is still pretty clear but I noticed some green algae along the walls and hundreds of small "colonies" of black algae. The black algae colonies are like 1/4th the size of a dime or smaller. They are clustered in the worst spots like at the 90 degree angle between the pool wall and steps. Anyways, my pebbletec floors also has black specks in them so its kind of hard to distinguish if its the pebbletec or black algae at some spots especially on the deeper end of the pool. The ones on the shallow end I have confirmed by touching and examining it. Any advice? How do I know when I'm done?
I've read through the Black Algae guide and am starting the SLAM tonight. I tried scrubbing the black algae today but I barely noticed any difference. I'm guessing it just takes time for the chlorine to kill it after you scrub off its protective barrier. I have my own (good) testing kit but the pool store also found that I have 450 of phosphates. Is this something that needs to be treated?
