I am now taking care of my MIL's pool. I recently replaced the main pump due to it leaking. As I'm trying to get the water chemistry in line (pool has been neglected), I am trying to map out the plumbing and find what might be a leak. I have identified the drains- two skimmers and a main drain. However, there is a 4th pipe plumbed in with the drains that I have no idea where it goes. The 4th line is 3/4" with a ball valve. The line is in the red box:
Any idea what that could be? I know that if all the drains are open, the water level in the pump drops and the pump will not prime. Not sure if the leak is in the drain or the skimmer yet, but I know that if the 3/4" line is open, the water level drops in even if all three drains are closed. If I run the hose directly into the pump basket, the pump does not over flow except when I have one skimmer open and everything else closed. If I start the pump with one skimmer open, the pump works fine. If I then open the other two drains, the pump continues to work fine. But it the pump is turned off, it will not reprime and start again. Just trying to get a handle on the basic layout before I call a pool company to come look at it.
