today is plumbing. Last night rain created some issues but work is going on as we speak on all plumbing related items. Next will be a little break since the city will have to do their inspections. Then its gunite I believe.
Hi! We’re in the process of permitting for a pool in flower mound. We’re getting hung up on additional info for installing the h/c and need all electrical specs and diagrams for it. Was this your experience as well?plumbing all done.
We built 14 years ago but it sounds like Flower Mound is still a challenging permit process. Our primary issue was running gas from an existing stub for the grill to about 25’ farther away. We were initially told it would take an completely new gas line at a cost of about $2500. I pressed the builder to at least try and I’d take the risk if it didn’t pass inspection, since it was going to save a bundle if it worked. Inspection was done in the morning during early spring and cold overnight temps kept dropping pressure to a couple of pounds below spec. Finally got the inspector to test in the afternoon and it passed!Hi! We’re in the process of permitting for a pool in flower mound. We’re getting hung up on additional info for installing the h/c and need all electrical specs and diagrams for it. Was this your experience as well?
Who is your pool builder?No fortunately for us the flower mound permitting was fairly quick. The inspections have been as well. We had our gunite put in 10ish days ago. Next step is tile and coping.
Not getting a spa either...just trying to do my homework because our pool builder is quoting 1000 for these drawings. Seems outrageous for a standard piece of pool equipment that a lot of people get!We will have a heat pump installed but no spa, so that may be reduced the complexity of the permitting with the city?
thanks for the insight. Got all pool equipment today and plumber coming by today for installation. Then electrical work.
thinking of adding an infrared heater, any thoughts on that for anyone that had one installed? also any other ideas that were good additions that electrician can do?
