Good day. I need help wiring my pool pump to the Wi-Fi box. The pump has two hot wires and I’m also attaching a picture of the existing switch and connections any help would be greatly appreciated.
Why do you have a switch at all? I would have thought that your Aqua Plus would be controlling your pump???
You have a 240 volt switch, and you have no neutral. I am not sure that you will find a WiFi Switch that can handle 240 or work without a Neutral wire. But then I don't have a lot of experience with WiFi switches..
I just installed it and it works perfectly. I am also attaching the wiring picture. Circuit braker hot wires go to com1 and com2. The pool pump hot wires go to NO1 and NO2. The jumpers go from AC to COM1 and COM2.
