- Jun 5, 2024
- 102
- Plaster
- CircuPool RJ-45 Plus
I don't know about you, but Murphy and his laws are never far from me. If it can go wrong, it likely will. In my case I have moved from a single speed pump to a VSP. Previously the SWG was wired to the timer with the pump so that it could never get power without the pump getting power. The VSP has constant power to run the programmed schedule so the SWG loses that little bit of protection and must rely on the flow switch entirely.
I could do this easily with various wifi enabled devices but that adds opportunities for Murphy to have fun with me.
AC current measuring switches are available with adjustable set points. I can connect the switch to a 2 minute time delay then to a relay powering the SWG. Adjust the setpoint to trip at the lowest speed/current I need for the SWG. The time delay gets it past any priming issues. I hate seeing my SWG flashing all the lights while the flow switch is dealing with pump startup.
Does this make sense?
