Reactions: Jimrahbe
I am hoping to connect an ew11 to my Easytouch, and have read that I need to get the antenna out of the metal box for a good signal. Should I use an extension cable for the antenna, or an extension cable for the rj45 connector? Any suggestions on what type of cable I need?
You will want to use a shielded CAT5e or higher for the RJ45 extension. DO NOT try to extend the antenna port. It will only lead to issues.
Also, I am using the EW11 for an AquaLogic controller:
Reactions: Jimrahbe
