I'm new to TFP and stumbled across this thread while searching for CYA information.
I thought to add my experience since it seems to support the findings discussed above.
We purchased a house, complete with pool in December 2012. It had been for sale for almost a year but the pool water was immaculate because it was under "pool store care". Being new homeowners we couldn't afford to pay someone else to take care of the pool so we chose to 'learn quickly'!
Being pool newbies, the first thing we did was pick up an AquaChem pool care guide in Walmart and follow their 4-step program (I know, I can hear you all slapping your foreheads in dismay!). We used up all the chemicals left behind with the home purchase and wasted a fortune on the AquaChem way.
As spring approached and the water warmed up, we were quite pleased with ourselves that we had a beautiful clear sparkling pool.
Then summer arrived; hot and humid coastal GA summer - and we started to use it in earnest a few weeks ago. Did I mention we were just using the 6-way test strips?!!
Everything seemed great until you guessed it.... almost overnight - green algae bloom.
Fortunately, that's when I discovered this forum and The Pool School!
I patiently converted to the BBB method, got rid of the algae, and learned about DE to clear up the cloudy aftermath.
I had our pool back to clear and chemically balanced happiness, the day before we went to summer camp with the boy scouts.
I forgot to ask our neighbors to throw some bleach in while we were away (won't make that mistake again!).
So of course, we came home to a green pool again!
Green pool. Blah! Not too worried - I know how to fix it now (and I invested in a TF-100)
Tested. No chlorine. No surprise.
Being a newbie I nearly didn't bother testing CYA again since I thought it didn't change much. Wrong! I was surprised to discover a huge drop in a week, from 70 to 20.
Here's the history:
Day before we left:
Chlorine: FC 6, CC 0.5
pH 7.8
TA 145
CH 155
CYA 70
Water temp 86F
Using The Pool Calculator, I added bleach at green algae shock level and muriatic acid to lower pH to 7.2, leaving the jets up to aerate, the goal being to lower TA.
I suspect I hadn't quite killed all the green algae from the previous bloom and it got a quick hold.
We had a couple of days full-on southern sunshine, then phenomenal amounts of rain (our rain gauge was full meaning over 5.5" during the week we were gone).
I had to empty some water from the pool when we got home because the water level was too high.
Today's results:
Chlorine ZERO.
pH 8.2
TA 120
CH (not tested)
CYA 20
Water temp 86F
The weather forecast is for a lot more rain and cloud so I thought the low CYA levels would actually help the Chlorine be more efficient to kill off the algae while the sun is not a problem but I thought I'd better find some CYA ready to raise the levels as soon as the sun arrives again. I was on here searching for CYA sources when I found this interesting thread....
I've used bleach to green algae shock levels again today.
We won't be swimming until the algae clears but we'll be adding more muriatic acid to get the pH back down (and depending on my CYA source, it may get some help).
Hope this adds to the data for the chem-geeks out there.
Happy pool time
