Deep end is cloudy
rchesani
8
Evans, Georgia
Hayward Aqua Rite (T-15)
We can’t get the deep end to clear up. Do I need to SLAM again? Any advice greatly appreciated!
Pool
Build Type: Vinyl
Volume: 29160 gallons
Latest Test Result Summary:
FC: 6.0 (26 minutes ago)
CC: 0.5 (26 minutes ago)
pH: 7.3 (26 minutes ago)
TA: 90 (26 minutes ago)
CH: 125 (26 minutes ago)
CYA: 60 (26 minutes ago)
SALT: 3000 (26 minutes ago)
Your PoolMath logs are for a hot tub.
Did you complete the SLAM Process passing all three criteria the first time?
I have a hot tub too. I thought I shared the pool log🤦🏽‍♀️ How do I change that?
We usually take the cover off and the pool is almost ready to go. This year we had a swamp. We were putting tons of chlorine/shock and basically throwing money away because it did not have enough stabilizer and the chlorine would be gone in 24 hours. So we basically started over and now that the stabilizer is good it changed the SLAM number to a much higher number so I thought maybe I changed something in the app. It tells me I need 5+ more gallons of liquid chlorine to get a recommended SLAM level of FC 28. Does that sound right?
Thanks again! I started testing my own water last summer and this will be first year I have not been to the pool store.
If you completed a SLAM you did not record much information. It is really helpful to you, and us, if you enter everything you test, add, do to the pool into PoolMath.
If the pool is cloudy, time to start the SLAM Process
