Deciding between Intellichlor IC-20 and IC-40
AW139
117
Ontario, Canada
Fiberglass
30,500 L (8000 gallon) fibreglass pool, currently using liquid chlorine. This is the first year I have had this pool, and I definitely made a mistake by not installing a SWG during installation. Oh well.
Next season I’m going to install a SWG, but I want make sure that I’m getting the right unit. I currently have a Pentair Variable Speed pump running at low RPM 24 hours a day, with a bump in speed for a few hours. I’m looking at either the Pentair IC-20 or IC-40.
If I choose the IC-20, I would need to run the unit at 30% to produce about 3 ppm chlorine. Right now my chlorine demand is around 3.5 per day. Is there any benefit to choosing the IC-40 to increase the life of the cell? With the IC-40 I lose the ability to make fine adjustments to chlorine output since the unit is only adjustable at 2-4-6-8-10-20-40-60-80-100 percent outputs. According to the Pool Math app, each 10% output level would be about 2 ppm FC on the IC-40. With the bigger unit I might have to keep switching outputs to maintain constant FC.
If you don’t have automation, I would suggest getting a Hayward Aquarite or Circupool swcg.
Are you near the US border and willing to use a Mail Drop? Circupool RJ30 would work well.
In Canada, the Aquarite from Hayward. A T9 or T15.
Reactions: AW139
Having a look at the Aquarite. I like that it’s finely adjustable down to the percentage. In that case I might as well get the bigger cell, considering it has 50% more chlorine production over its life for only a 14% increase in price.
Any reason to not go with a SWG that has 5 times the rated capacity of my pool?
Not operationally.
You may or may not get all the life out of it before some other issue causes it to fail.
I just took a peak at replacement cell costs, and there actually isn a decent difference in price between the T9 and T15. I ran the numbers, and the savings aren’t much over the life of 2 cells. If the bigger cell were to fail early, it would actually end up costing me more. Even with the 25k gallon cell, I would still only run around 25% output.
Thanks for the help. This has helped clarify some things.
Reactions: mknauss
A 20k unit would be 2.5X your pool volume and with such a short and mild season, it's borderlining on overkill. That's as high as I'd go for you, unless the price was right on a larger model.
For example, an IC40 has a sale that make it the same price as the IC20, or the circupool 30 is the same price as the IC20. Then, by all means go larger.
Reactions: AW139
Makes sense to me. I’ll keep my eyes open for a deal.
I’m going to finish off the season with liquid chlorine, and then install the Hayward Aquarite 25k when I open the pool in the spring.
The amount I have learned over the past two months alone thanks to TFP is staggering. You guys here really are helpful.
