Decent leak from above ground pool pump
jcrew6311
94
Arizona
2nd year using this best way pool pump. I know people mention they're not great, and I wasn't expecting a miracle. However it has worked great to keep our pool clean for a whole year and now going on 2. 1 problem though, there's a decent running leak coming from the frame and I'm not sure how I can get it to stop. Is there some kind of sealant I can use to fix this?
Also, it was supposed to be a video attached but apparently it just turned it into a picture. You should be able to get the idea. It's not just a light drip, it's a consistent running leak.
I don't recall that pump. Is that a Bestway model or do you know what make/model it is? Hard to tell form the small pic, but it looks like it may be leaking at the seal plate area where the motor and pump basket come together. Any chance it's leaking at the collar/union connection above and just running down?
