I have a newer arctic spas hot tub with the Gecko IN.YE 5th Generation pack. My 50 amp breaker had an issue and shorted. Thats a long story in itself. I replaced the breaker but now the tub is not working at all. No lights on the control panel nor on the circut board. I have tested and confirmed there is 240v at the spa pack.
I tested the 3 fuses with an OHM meter. the meter shows a value of 1 or 2 then immediatley drops to zero. I believe this means the fuses are not bad?
Not sure where to go from here.
