Dead algae
SteelDan
4
Dagsboro, Delaware
I have a fairly small amount of algae on the pool floor. I know I need to balance the chemistry. I’ve been reading how to get rid of the dead algae. I have a vac that attaches to my skimmer and a polaris robot vac.
I’ve read that you must vac the pool on backwash to eliminate the dead algae (gray wispy stuff). Is this correct? Do I need to use a flocculent? Is there anything else I need to know?
No FLOC please...dear lord no. Dealt with 2 floc pools this week and were a mess.
How do you test your water? Do you have a test kit? If not, get one. Link-->Test Kits Compared
If you have a test kit we recommend, post a full set of results.
If you don't, add 3ppm of liquid chlorine PER DAY until the test kit arrives, nothing else.
If you have a recommended test ki, or when it arrives, follow the SLAM process to clear the pool. Link-->SLAM Process
What kind of filter do you have?
Need Proof? Link-->How Clear is TFP Clear?
Chlorine gets rid of algae.
I have test kit and sand filter
I have a sand filter
