I have a problem that started last season, which what I believe has been dead algae appearing on my pool floor. Pool water was perfectly clear, little smelly, and once I turn on the pool pump after robot vacuuming the floor then what looks like dirt/sand comes back immediately. It’s not dirt because when I touch it, it will puff up and disappear. When I learned about the SLAM process on this site I ordered up the TF100 kit and went to work. Seemed like everything worked decently with the SLAM but I suspected the water wasn’t quite perfect as I noticed a little of the algae coming back; however, it was time to close the pool so I figured I’d get back at it when I opened the pool, if necessary.
I opened the pool and sure enough I had the issue still. So I SLAM’d. I went so far to hold the SLAM for a week extra after passing the overnight loss test, and continued to test every day still. Everything looked great with the testing and water clarity and no evidence of the algae. Only issue, my pool liner looked to have some staining, I suspected it was metals so I added metal stain remover. The stain seems to be gone now, however, after almost a week after completing the SLAM I am getting this “dead algae” forming again. Any suggestions?
Currently:
TA 100
PH 7.4
CYA 60
FC 4.5
CC .5
Above ground vinyl lined pool.
Thanks!
Matt
Currently:
TA 100
PH 7.4
CYA 60
FC 4.5
CC .5
Thanks!
Matt
