Our Hayward sand filter, which is probably 30 years old, suffered a cracked standpipe in August last year, so we replaced the standpipe and laterals and because the sand was over 12 years old, we dumped it and put in fresh sand because it needed to be deeply cleaned anyway. We also replaced the key cover and handle assembly, which I wish I had done sooner.
The pool is under oak trees, and they are not our oak trees to cut, and it would likely kill them if we cut them off at the property line, so we are stuck with them. As a result, the pool is full of pollen, and the new sand in the filter is not clearing it. Last week, we added a cup of DE to the skimmer, 1/4 cup at a time in a bucket of water. The pressure did not budge from 11.5 psi (there's a heater on the pool). I stopped at one cup to be sure. The next morning, it was 18.5 psi. I backwashed for several minutes. No change in the pressure. Overnight it jumped to 21.5 psi. We backwashed several times. No change.
I changed the gauge for a liquid-filled new one. It reads 9 psi. The disconnected gauge still says 21.5. So that was broken.
Do I add a bit more DE? Because the pool is still cloudy with a slight yellow tinge from all the pollen (the catkins were filling the skimmer basket within hours over the past week, but I think they are all done falling). Or just leave it be?
13000 gallon fiberglass pool
