Ok, was cleaning the grids a couple of weeks past, noticed that the O-ring for the bulkhead was missing. Mind you I've never had a problem with DE being pumped back into the pool but out of an over abundance of caution called a local pool company and they sent a guy out with about 3,000 assorted O-rings since they did not have the exact part in stock. The guy fished around for a while found one that seemed to fit, we lubed it and he jammed the manifold down over it, pronounced it good to go. To me it looked a little askew, but none of the grids were touching the sides, so, ok, he's the "pro."
Mixed the slurry, started pump, poured slurry in skimmer, whoosh! I could see the DE being pumped back into the pool through the nearest return.
Took off the pump top, pulled the manifold, saw the O-ring twisted around the bulkhead, took it off, put the manifold back on, DE still going back into the pool!
This did not happen before the wrong O-ring was installed. I've called another pool company, one that I trust and order the correct one, though it's on back order.
Can I put some Gorilla tape around the bulkhead/manifold connection temporarily until the correct ring arrives? I am worried that by the wrong ring being jammed into my manifold that it somehow screwed up the pvc pipe.
thanks,
ed
thanks,
ed
