DE For Sand Filter
sktn77a
2,638
Chapel Hill, NC
I'm using some DE in my sand filter to clear up some cloudiness in my pool water. Chemistry is as follows:
FC 9.0
CC 0.0
CYA 50
pH 7.5
TA 100
CA 300
Looks good to me(?) I added a couple of cupfulls of DE slurries into the filter (making sure it dissolved as a slurry as I was doing this). The DE I'm using is the following:
https://www.amazon.com/gp/product/B00TEDE9GK/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Hasn't done squat - if anything it's getting worse! Also, the pressure hasn't increase at all. I thought the pressure would inclease as the DE coated (clogged) the upper layer of sand in the filter.
Is the DE going straight through the filter and adding to the cloudiness?
Thoughts?
Thoughts?
Maybe. You purchased the wrong thing. You want pool grade DE, not food grade DE.
I actually use Cellulose Fiber DE Replacement
https://www.amazon.com/Pro-Guard-23793BPG-Cellulose-Replaces/dp/B00D3J3G4W
If the pressure isn't going up, you are NOT increasing your filtration.
Now, on to another issue. Do we know the cause of the original cloudiness? Dull, then cloudy water are the beginning signs of algae. I would say an Overnight Chlorine Loss Test is in order to eliminate the possibility of something growing int he water. Filters don't remove algae....
Ah, OK, so this stuff won't do anything? What's the difference between food grade and pool grade?
The pool was a little cloudy (milky-like, not green, yellow or brown) beforehand but I had just added stain-free and metal magic, so I assumed that was the cause.
Well, I did a little more research on this and it turns out food grade DE is structurally and chemically different to pool grade DE. Importantly, it is a much smaller size and passes through the sand filter - hence the cloudiness. Oh well, live and learn!
