- Jun 5, 2011
- 1,180
- Plaster
- Jandy Aquapure 1400
I just cleaned my filter and can see what I assume is DE flowing into my pool from the pool returns - small specs of white reflecting in the sunlight. I noticed it mostly in the spa, as the water became cloudy once I started the pool back up. I’ve had the pool for 13 years and have never seen this before. Filter pressure was only 22 psi when I cleaned it. There’s a “sock” over the what Hayward calls the flex air relief assembly that is torn, exposing what looks like a vent. It’s been torn like that for a year or two, so I doubt that’s causing the DE flow. I’ve looked at the Hayward parts diagram and they don’t show this sock, but it’s something that can easily be replaced as it is held on with a clamp. Anyone know where I can get a replacement? I should have taken a picture, but filter is reassembled now.
Should I just wait to see if the DE flow stops and clears up? Thanks for any advice!
