I bought a house with a pool last year. It has old Anthony Pools equipment. Last year everything was working perfectly. Water was clear and pressure stayed 9-10 PSI. Pool was property winterized.
Several days ago I opened it. Water was pretty green with some stuff on the bottom.
I vacuumed the bottom "to waste" than run Dolphin cleaner. Bottom is pretty clean now.
I put shock and some other pool opening chemicals ("Metal Out" and stabilizer). Test shows 7.4 PH, 120 Alkalinity, 30 Stabilizer, 300 Hardness.
Couple days after opening I noticed that pressure went up to 25-28, so I thought that its time to clean the filter. I opened the filter and power-washed all old DE, then sprayed it with "DE Filter Cleaner", let it stay and power-washed it again. Than I put it back and added DE.
Pressure went back to 8PSI .. for about 4 hours.
That's it. No matter what I try pressure stays at 29-30 PSI and there is almost no water flow. If I backwash pressure goes to 8 PSI for about 10-20 minutes then raises to 30 PSI.
Everything was normal last year, so it's not an "over-sized pump" issue.
I see some tiny air bubbles flying though the check valve, tried to check for air leaks, could not find any. I also tried to open filter, take out the grids and run it empty. Pressure was steady 8 PSI. So I doubt its an air issue.
Water is still a bit greenish and cloudy, but much better then it was right after opening.
So what could it be and what could I try to diagnose or fix it?
Thank you.
Michael
Thank you.
Michael
