I have an old (10+ years guess as original install unknown) Nautilus 48 DE filter that has sprung a leak on the drain has cracked. Tried to repair it with epoxy but although the leak has reduced from spray to drip it still leaks, and I noticed another small leak on the front were the multi valve connects on the rubber part on the tank.
Considering a new replacement and the pool service company recommended that i switch over to a Sand filter as it was less maintenance but still did a decent job cleaning.
I have read many posts around here and most seem happy with Sand possibly with a bit of DE in it.
How often does sand need to get backwashed? I am seeing people say weekly some monthly. My DE filter can go 1.5 months without need for a backwash and a full clean about every 3 months with fiber clear medium.
I am considering another DE filter, Sand or possibly a cartridge filter look interesting also. Can you all provide your recommendation and why? Your opinion and info are greatly appreciated.
The rough estimate was about 1K for the new filter and 2 hours of work at 125 an hour.
