Hi All,
I'm a new pool owner as of last year and this is my first time opening a pool and I'm hitting a few speed bumps I was hoping to get some guidance on. I have a Hayward Perflex DE Filter. We had a mesh cover over the pool during the winter so we had a pretty dirty pool as of this weekend. We've been running the filter and vacuuming it daily and it is getting better. I can actually see the entire pool now. But the pressure maxes out really fast. I'm bumping the handle every few hours. Default pressure of about 15 psi, and we lose flow at around 25, I try to bump it once its at about 23ish. This is even worse when we vacuum. It needs to be bumped after about 10 minutes and just gets worse. We've back washed it maybe 5 times now and it seems to immediately help the problem but doesn't take long to be back where I was.
Currently the plan is to vacuum again tonight and bump it till it stops being effective, backwash and repeat until the water cleans up and I'm hoping once the water cleans up it'll be more stable.
Am I going about this right? Should open it up and hose down the fingers (this was done at closing). I am aware of acid baths but not sure if they are appropriate for my filter or this problem.
Thanks
Edit: Oh and I'll add that I'm working on the chemical levels as we speak. Everything is pretty good, chlorine overall is high but just shocked it last night.
Thanks
