- Jul 21, 2013
- 65,336
- Plaster
- Pentair Intellichlor IC-60
1. I am targeting CYA 30.
It's my understanding that in general pools chlorinated with tablets or liquid chlorine should have CYA up to 40ppm, so 30 is a great starting point as CYA can only grow over time?
CYA 30 is best for the SLAM process.
2. Then, following the 7.5% rule, the FC should be 2.25ppm?
You do not want to run your FC at the minimum. The minimum is a never drop below number.
The Free Chlorine and Cyanuric Acid Relationship
Managing your cyanuric acid and Free Chlorine levels is key to stabilizing your pool. Learn how these two items affect each other.
3. But this is the level I should maintain when the pool is healthy but since that's not the case right now, I will maintain it at 12ppm to purge the contamination/algae?
Correct.
4. This pool isnt in my home - pretty far away from it so I can only visit it early in the morning, before work and maybe twice at night after work.
Do the best you can as often as you can.
So I can add the LC once early in the morning or twice at 6-7PM and 9-10PM every evening
Although I have CYA 30, isn't it still better to add LC in the evening, so I add LC twice every evening ~3 hours apart and never early in the morning when the sun will beat on the FC anyways?
No, that lets the algae grow and party during the day.
