Had a major kerfuffle this morning, when a family member, mistaking a gallon of Muriatic Acid for a gallon of Chlorine, added the entirety of the former to our pool. I walked out about fifteen or so minutes after it occurred, and wandered why an empty bottle of Muriatic Acid was sitting on the pool deck when I found out what had happened (last time I let anyone else help out on the pool). I immediately backwashed as much water as I could out of the pool, then added what little PH+ we had (maybe a pound or so), and turned the water hose on full (our water has a high pH level) and ran it through the skimmer with the pump going. Fortunately, there was a pool store open, and I picked up some Soda Ash, of which I ended up putting in approximately 5 lbs until I had got the pH stable at 7.5. I added some extra Calcium Increaser to bolster the calcium hardness levels as well. About the only positive I could think of is that our water has a very high alkalinity level (300-400 PPM), so I'm hoping that might have helped by providing a counterbalance to the acid.
Now to the point of my query, just what kind of damage did this do to the pool? It's about 15 years old (needs a resurfacing), and as our water has zero calcium in it, despite best efforts, there have been issues with inadequate calcium hardness levels in the past (prior to my taking over maintenance), so I imagine the walls aren't in the best of condition to begin with.
Is there anything else I should be doing in regards to the chemical levels, or just let it sit until everything rebalances?
Also, are there any visible signs of damage that I should be on the lookout for?
