- Jun 24, 2021
- 7,649
- Vinyl
- CircuPool RJ-60
Pool is great and running good. Installed Stenner on smart plug and using Alexa routine to start and stop smart plug. Works great. I test, then adjust "pool pump off routine" to end at the appropriate time for the amount of chlorine I need.
What I want to do is to set a "normal amount" and let it run for the week rather than testing everyday.
General FC results:
Pool cover on all day FC Loss: 0.5
Pool cover on part day and some swimming FC loss: 1-1.5
Pool cover off all day (sunny) and swimming FC loss: 2-2.5
If I take the results for the last 10 days (Actuals below) and use 1PPM daily addition, I get 3.5 Min. If I use 1.3PPM addition, my average is 7.5 end of day, min of 6 and max of 8.8.
The question. If I am cognizant of "sequence of demand" issues (i.e. multiple days remaining covered (low deman), or multiple days uncovered/sunny/swimmers high demand). Seems to make sense that I can run at 1.3ppm daily addition and weekly tests.
Thoughts?
General FC results:
Thoughts?
