mknauss beat me to the post about your SWG and increasing the time.
See:
The Free Chlorine and Cyanuric Acid Relationship
With CYA at 80, you should be running FC at 6-11. 4 is the bare minimum, and can dip into the algae zone really fast.
PoolMath calculates your SWG is currently only adding 2.2 ppm. Running the pump 24/7 would max it out at 5.5 ppm
Boost your FC using liquid up to the 11 ppm, and play with the pump time (SWG always at 100%) to find what amount keeps the FC at the 10-11 mark. Given the lowish max amount it can do in 24 hrs, you may find the pump has to run even longer than 15 hrs during high summer when Cl losses are the highest.
Others that run lower SWG %'s are using cells that are oversized for the pool - so they can cut back both on run time and %. Jandy says it is for up to 40,000 gal. - and is the biggest they have. But at only a rated 1.25 lb/day, it actually is on the smallish size for your gallons. It should keep up, but has to work more to do so.
My pool is 23,000. My RJ45+ nominally can do 2lbs of CL per day. Running 24/7, I can maintain at 40-45% (therefore making .85lb/day). But at only running 10 hrs, I'd have to be at 100%, and might slowly fall behind (making .82 lb/day). Your lb/day needs will be different, depending on a host of factors about your pool and climate.
