Tested my water this morning and thought I would just check my CYA since I used 7 gallons of chlorine in January so far and was thinking I should be using a lot less. Anyway here is what I got.
CC 4.6
CA 220
PH 8.0
TA 80
CYA 0 ?
Does cold weather effect CYA readings or 8 month old regents gone bad or any other ideas. I last checked in November and it was 50. Now it is clear all the way to the top of the comperator tube, and no cloudiness at all. I have not backwashed or drained any water since then also. Very curious, maybe I will order new reagents on Amazon unless you guys have any better ideas.
CC 4.6
CA 220
PH 8.0
TA 80
CYA 0 ?
