Using bad test strips allowed CYA to go to about 160 ppm according to my new Taylor K-2006 test kit. I super chlorinated the 15K pool with 10% NaOCl and a week later the FC is still high at 25 ppm. This was done to get rid of a bad algae problem. The pH is a bit under 7.0 and the base demand test calls for about 2.5 lbs. of soda ash. My question is, if all other parameters are OK, is a FC level of about 16 ppm going to sanitize my water and still not irritate the swimmers? Of course I am not going to add stabilizer and plan to drain about half of the water when summer is over.
