- Jun 22, 2022
- 98
- Plaster
- Hayward Aqua Rite (T-15)
Hey all. Long time follower, first time poster. I’m pretty well studied on the philosophies of the community as well as the pool chemistry basics etc., but needed a little help making a decision. Going against community advice, I had been using pucks in the pool at my rental for some time due to higher pH and low CYA. Unfortunately, the situation got away from me and on last test the CYA was coming in at 85 ppm (I’m using the TF-100 kit). Chlorine was also high at 7 ppm when it had been hovering around 3 so I’m thinking the pucks started dissolving at a higher rate for some reason (maybe rising summer temps?)
Anyway, need to decide, should I drain and replace to get the CYA down to the recommended upper limit of 60 ppm for chlorine pools or is it okay to discontinue pucks, and let it ride and come down through attrition? In your experience and knowledge, do we run the risk of having low chlorine activity at the 85 level? If I do ride, maybe I should maintain the chlorine at a bit higher levels for awhile?
What do you guys think?
