I got two different readings testing CYA yesterday and testing it today. Yesterday, I stopped adding mixture when the black dot was no longer truly visible -- just sort of dark down there. Today I tried adding solution until the black dot couldn't be seen at all -- not even darkness... and obviously, the CYA read as lower today because I did the test slightly differently (more solution). So, when the test says to pour in the solution until you no longer see the black dot, do they mean you should see NO trace of darkness down there or is it good enough to know it's darker but not see the circle itself? Basically, how far should I go in trying to obliterate the view of the dot?
