Hi from a new member! Just took over testing my own pool water last month. I'm sure I'm making this CYA test reading more difficult than it should be. For an accurate reading, results are recorded in 10 ppm increments like 30 or 40, not 35, for example? So, if the water level is between those two when the dot disappears from view, the result is recorded as which?
I need to SLAM my pool today due to yellow algae appearing after heavy rains yesterday and want to make sure I raise the chlorine level adequately.
Thanks!
Thanks!
