- Jun 22, 2013
- 352
I still have issues with the CYA test. I have the Taylor kit. I recently purchased the reagent, view tube and standard solution from TFTestkits just to compare. The standard solution is 50ppm. It says use it like its your pool water. So I add it to the mixing bottle, then add the reagent... shake.... poured it into the view tube to the 50ppm line, and I still easily see the black dot...
This makes me wonder if I really knoiw what my CYA level is or not.
Am I not doing this right?
I should add I also purchased the TFT mixing bottle as well...
