Coinciding with a new order of some reagents I have ordered too a 50ppm CYA standard solution from TFTestkits, the results are pretty much the same as last time. I can see quite clearly the dot at 50PPM and at 40PPM I can feel that it is there.
In any case this s useful to me as I am able to calibrate my measure, I think that I am able to repeat the test consistently to see the dot like in this 40PPM and I will add 10PPM to the measured result.
I did something similar time ago: CYA standard solution test result, can I extrapolate?
