CYA - Stabilizer vs Pucks
#1
If my CYA would drop to a level of X and I needed to up the level to Y.
Could i just stop using the BBB method and switch to pucks until my CYA level reached a suitable level?
Is there a reason I would want to only use a stabilizer?
Thank you,
woodyp
10,206
East Texas
#2
Hate to tell ya', but you'd STILL be using the BBB----now TFPC method because you realize exactly what those chemical additions do and how they effect your pool water balance. As to which to use......depends on how fast you need to get where you want to be.
BasicTek
800
Lake Mary, FL
#3
I had a giant vat of pucks leftover when I went to SWG, you can use pool math to calculate how many pucks will raise your CYA the amount you need. I do this all the time, pucks also bring down PH if you find it rising often and add a little salt....
Sid/
32
Sachse, Texas
#4
I’ve seen some videos on adding the grandular cya via the skimmer and others that say to put it in a sock and place it front of a return. What is the best way to add cya to a pool????
bmoreswim
Platinum Supporter
4,271
Central MD
#5
Sock method in front of a return (with the pump running) is our recommend method. Various reasons but it’s the best method. Squeezing often can get it dissolved in a few hours.
Oly
470
Fresno, CA
#6
Yes and get an good idea to predict how much CYA is added by using Pool Math. For small additions to raise CYA slowly I use the trichlor pucks and try to plan it during a vacation.
The stabilizer compound, CYA is the same so apply what you need by knowing what you are applying.
Sid/
32
Sachse, Texas
#9
Walmart has the Clorox brand stabilizer. 4 lbs for $14.86. It’s the grandular type. Label says 100% cya. I’m doing the sock distribution way to put into the pool. Thanks for the advice
