- Apr 26, 2021
- 76
- Vinyl
- Pentair iChlor 30
I am trying to figure out a couple of things. I have added 70 ounces of CYA over the past 2 weeks, and it only raised by 10ppm. Over that same period, my salt reading has gone up by 400ppm without adding any Salt. I have tested these numbers several times in the same sample to confirm. EDIT: I checked the SCG and it is stating that I have 3300ppm salt. Maybe the R-0630 or R-0718 is bad? The best by date for R-0718 is 8/24.
Is it possible that my Robelle CYA from Amazon is really just Salt? Why did my Salt increase so much? Could be reagents be bad (definitively before the best by date and no funky colors during testing)?
Unrelated or maybe it is related, my Combined Chlorine has not gown down, and remains constant. Is this SLAM worthy? Any thoughts suggestions, or ideas?
I am going to the pool store
cautious
to test the water and pick up some liquid chlorine to be prepared and to double check the numbers (I wonder what Leslie's testing will show).
Date | Free Chlorine (FC) | Combined Chlorine (CC) | Total Chlorine (TC) | pH (pH) | Total Alkalinity (TA) | Calcium Hardness (CH) | Cyanuric Acid (CYA) | Salt | Temperature | CSI | Notes |
5/31/2024 | 4.20 | 0.00 | 4.20 | 7.9 | 80 | 250 | 60 | 3,400 | 77 | -0.060 | Set SCG to 40; Backwash; Added 16oz DE; Fixed Flow Rate (O Ring Cap to Pump) |
6/1/2024 | 3.80 | 0.20 | 4.00 | 7.9 | 80 | 250 | 60 | 3,400 | 78 | -0.060 | Set SCG to 45; Pump 24/7 2,600/3-2,200/9-1,800/12; Added 32 ounces of Muriatic Acid |
6/2/2024 | 2.80 | 0.60 | 3.40 | 7.4 | 70 | 250 | 50 | 3,400 | 80 | -0.580 | Set SCG to 50; Brushed walls; Added 48 ounces CYA |
6/7/2024 | 5.60 | 0.60 | 6.20 | 7.7 | 80 | 250 | 60 | 3,400 | 79 | -0.240 | Added 24 ounces CYA |
6/14/2024 | 9.00 | 0.60 | 9.60 | 7.7 | 80 | 260 | 60 | 3,800 | 79 | -0.240 | Air bubbles in pump basket |
