My initial CYA was more than 100 as per Taylor so, I'm not sure what was actual....It could be 120 to 150 may be more.
Drained %80 of pool and filled it up. Started running filter when water level at %50
At this stage added chlorine. 38oz ( estimated pool capacity 12000 Gallons)
When water reached level at %90, got tested at 50F temp (yesterday at around 4pm)
CYA was still over 100.
FC 9.0
CC 0.2
PH 7.4
TA 7.0
CH over 500 ( before started drain/fill that number was same, and supposed to be at last little goes down but result not changed)
CYA still over 100.
Dallas is cloudy nowadays and light was not enough when CYA test done.
Temp may impact the result?
and to reading more reliable CYA value, at last needs to wait 24 hours pool circulation ?
Thanks.
FC 9.0
CC 0.2
PH 7.4
TA 7.0
CYA still over 100.
Thanks.
