- Jul 14, 2017
- 751
- Plaster
- Hayward Aqua Rite (T-15)
Hi All -
Newbie here. Owned my pool for three weeks (came with the house I just bought) and we have high CYA - seems obvious that the pool has been chlorinated exclusively with trichlor for a while from the chemicals left for us in the garage.
So I finally got my first test kit to get an accurate measurement (Leslie's water testing gave us the first indication of high CYA) and it's about 130-140 ppm (measured 65-70 ppm at 50% dilution). I was planning on doing a partial drain and refill to fix the problem but now that I see how high the level is I am wondering what my options are. The biggest problem is I have is very limited options to drain to. It's a suburban neighborhood and I'd rather not flood out my new neighbors. The township guidelines are to drain into the sanitary sewer. I can do that with a submersible pump and garden hose into the basement drain but it is going to take most of the day if I need to drain 18000-19000 gallons (75%-80% for target 30ppm). Considering I need to constantly keep an eye on the hose going into the basement watching for overflow, that will be a real time suck.
Also I was wondering if there might be structural issues with draining out that much water and leaving the shell almost empty, even for a short time. Someone told me that empty pools can 'float' out of position.
So, if I instead pump and refill maybe 6000 gallons to at least get the level below 100ppm does that help me? That at least gets the level below what I understand is the 'danger zone'. Then I switch over to liquid chlorine instead of trichlor and maybe repeat the process again a while later, although doing it all at once definitely seems the most efficient from a water/chemical waste viewpoint. I was also wondering about trying the BioActive CYA reducer from Leslie's to help out although it sounds like it's really hit or miss whether it works or not from reading online.
Interesting to note that although the CYA has been so high and our chlorine levels very low since we moved in (mostly from ignorance as we lost track of it), we haven't seemed to have any problems with algae growth or anything visible in the water.
Advice?? Thanks
Advice?? Thanks
