k - i was losing FC pretty fast even with this CYA level - i discovered that i had a bio film in my deep end - i did a thorough brushing last night and added liquid chlorine, i also ran my robot with the fine filter and kept my pump at high speed over night. The water is very clear. Should i do an overnight loss test? Should I be thinking about SLAM?
If you had some sliminess or film, it could very-well be algae. But you certainly could do an Overnight Chlorine Loss Test to be sure a SLAM is needed. Remember when doing an OCLT the SWG must be off.
