CYA Loss
simonoaks
347
Juno Beach , Florida
Hi,
I have posted a couple of time about this over the last few years, and still do not really have a good understanding of what is causing it.
I noticed a gradual loss of FC , even though we are away from mid summer so technically I should be lowering my % on SWG as less sun on my North facing pool. However there is a gradual loss.
I tested CYA yesterday and it was way less than 30.
So I have gone from over 90 to less than 30 in 4 months. This is a common trend year round, every year. Any idea what is causing my CYA loss?
thx
Do you have an autofill for your fill water and/or an overflow for the pool if it gets too much rain?
Are the salt levels stable in the pool or do you have to add salt every now and then?
I manually fill pool, usually every 10 days , sometimes 7 days (it has been a very dry summer this year), maybe 2-3 inches fill per week.
We have not had enough rain to over fill pool this year.
I add a bag of salt about every 2 months.
Do you think I have a leak? I can imagine that is almost impossible to trace and fix. There is certainly no leakage around any of the main above ground equipment / pipes.
thx
I read on here someplace that Sun & heat can kill CYA. I’m also in Florida and this last month and a half I lost 30ppm of CYA, to the point where I went back to using the chlorine tablets I had in storage (using poolmath to help calculate CYA) to start building it back up.
High water temperature (90+F) can accelerate the degradation of CYA. I see up to 15 ppm per month during the summer.
I also see about 10 - 15 loss per month over the summer and still 10 loss per month in winter. I maintain a very hot pool around 90 from April to October and probably averaging around 80 from November to March. I have used only 1 bag of salt this summer and 1 last winter (3 last summer mostly due to irma) so I don't seem to be loosing as much salt. My pool does overflow a bit during the FL rainy season but I lose almost as much CYA in winter also with almost no rain and the pool covered. It's done this for 2 years so I've come to accept it's just what my pool does.
To note CYA can be bought extremely cheap in bulk on ebay, even cheaper when they have coupons. I actually bought a 4 gallon pack the liquid since I have to add it so often it was about $60 on ebay coupon deal (not available now). I'm on gallon #2 since June so it will probably last me a year and a half or so. I also float some leftover pucks I have on occasion...
thx
Almost for sure, You have a leak. Florida climate should result in a 1/4 or LESS daily loss. That would explain your salt and CYA loss, too.
Perform the bucket test to confirm but plan on the result being a leak.
Pool School - Leak Detection
