Oh where do I start?The direct current in the cell jumps from one plate to another, over time carrying part of the surface with it. That is why the best units reverse the polarity often. The coating is made of metals more resistant to that shedding than the titanium plates are. Same reason a platinum spark plug isn't entire coated with platinum, just the tips where the spark is produced.
And the lack of temperature difference and FC raise is demonstrable. You have a skimmer, you have a return. Take samples, test them, there's your answers.
You have water leaving your heater at well over 100 degrees and you think tiny little plates with a hundred watts of power running through them are heating the water in any measurable way?
The answer here is pretty obvious, but if you happen to have one of these double blind controlled studies you speak of up your sleeve we're always looking for new data to add to the collective.
Direct current does not jump!
It does not carry plates particles with it!
All units reverse polarity but to prevent scale buid up!
Plate coating(Ruthenium) is made of metals highly resistant to aggressive chemical corrosion not"shedding"!
Hypochlorous acid is a very strong oxidizer-it will corrode most metals and make them dissolve.
You need to pay attention to what is said-I never said that plates are heating the water.I said that plates are HOT!
I guess you are one of those people who belives that Sun circles the Earth "because it is so obvious,I can see it"
