- Jul 29, 2017
- 215
- Plaster
- Pentair Intellichlor IC-40
After getting all the new equipment up and running I found the CYA level to be 50. Current water temp is 58 with air temps in the mid 60's to low 70's.
I see the recommended CYA level is higher than that. With little risk of an algae bloom this time of year how urgent is getting it up? Will a week or two be a problem? I will place an order today but won't be able to get it in the pool immediately.
When I do put it in what is the best way to dissolve it, and should I turn off the salt cell while doing so? Another option would be to use up some of the trichlor pucks I have in a floater but that will take even longer.
