- Dec 17, 2017
- 667
- Fiberglass
- Astral Viron eQuilibrium EQ45
Looking at having a pool installed in early 2018.
I have been reading up on TFP forums as much as possible to gain valuable insight to running a pool (will be 1st time owner)... So far the forums have been a goldmine of information...
One thing that has been a little confusing is the manual for the pool chlorinator that my PB will be installing.
It is a commonly utilised unit here DownUnder - Astral eQuilibrium series chlorinator. eQuilibrium Chlorinator | AstralPool
I was looking at purchasing the version that has the auto acid dosing feature (fitted with PH probe) as well as having a dedicated probe to measure ORP.
In the manual the manufacturer effectively states (prefers) that users should run with no CYA present in the pool.
Reason being is that CYA levels influence the ORP probe's readings, which in turn tricks the chlorinator in producing too much FC.
They do state that if the user does use CYA then levels should be kept at 10 to 20ppm.
Their reasoning is that users should just rely on the SWG to produce enough FC during sunlight hours to counter the UV losses etc and little CYA will not affect the probe's output too much..
If I want to follow the TFP way... then I would obviously like to run CYA up at 70 to 80ppm (pool will be FG) to take advantage of its benefits (lower run time for SWG cell, reduced pump run time and its buffering effect on FC losses etc).
Can I not simply just offset the ORP set point to a lower mV value to allow for the probe's lower reading with a higher CYA level?
The user manual does go some way into explaining this on pg 21 - The manufacturer lists a short table of mV values wrt CYA and FC levels however it pretty much stops at 50ppm CYA levels.
Is there any detrimental effect in running CYA up at around 80ppm with an ORP probe for the chlorinator's chlorine feedback loop (providing I offset the ORP set point correctly)?
I'm not sure how linear the ORP probe's output is so I am not sure whether CYA levels at 80ppm will be workable or not for the ORP probe.
