- May 25, 2018
- 17
- Vinyl
- CircuPool RJ-60 Plus
I've been reading quite a bit in here, probably too much! Thanks to everyone for the insights they provide. We purchased a house with this pool several years ago and I've managed to get by using some combination of tabs and bleach as needed. I tested maybe 1x/week and always had small bouts with algae but generally kept the pH and FC in line with where they needed to be (used an older Taylor 5 way test kit).
Since I have added in a decent amount of bleach (8 gallons) and the FC barely budged, I figured there was a CYA problem and decided it's time I follow more of what you all are doing. I got a TFT 100 test kit and the readings showed CYA of 0 and FC of 0.5. The TA (90) and pH (7.8) are a tad on the high side, but the problem is no CYA. I have ordered some stabilizer and plan to put 8lbs in the pool (using a sock) before adding more bleach to raise the FC. Since this is my first time following the pool math app, am I missing anything? Thanks!
