CYA has crept up in the last 10 days.
sureshot
Active member
May 21, 2017
25
Dracut MA
Hi Guys, I have a 12500 gallon OGP with sand filter. Outdoor temp has been about high 80's to low 90's.
These are my readings:
CH 10.8
PH 7.4
CH 270
ALK 80
CYA 60-65
The pool is not using hardly any chlorine. My reading 4 days ago was CH 12. I was using trichlor pucks and stopped about a week ago. The pool is crystal clear and has been all season (about 5-6 weeks). Should I just replace some water to get the CYA down as pool math has indicated or is CYA 60 ok? Thanks in advance.
mknauss
23,066
Laughlin, NV
I would suspect the trichlor pucks were still in the system. You may not have added any, but some were still dissolving and adding chlorine and CYA.
Reactions: sureshot
