Hi,
I have a 20K gal pool with solar heater set at 87F, and I am using liquid chlorine. I see high consumption of CYA. The chlorine level sometimes falls to 0, but I easily bring it back to normal by adding more chlorine. So far, haven't had any algae problems, just a little cloudy water that clears up with more chlorine.
The issue is the CYA. My target is about 35ppm since I have a pool cover and the pool does not get much sun exposure. However, it keeps dropping. I add more from time to time, but now at the end of the summer it got to only 5ppm. I did not need to add much water since the cover prevents most of the evaporation, so it is not dilution by new water.
What mechanism leads to CYA consumption? And is it related to low chlorine?
I don't know if it matters, but I have a UV sanitizer.
I initially used liquid stabilizer from Leslie's, but after startup I have been using Clorox powder CYA from Walmart.
