- Jun 30, 2022
- 16
- Vinyl
- Pentair Intellichlor IC-40
I'm in the process of my SLAM, my CYA was around 70 when I started so was doing my SLAM based off of that. Fast forward to 4 days in and I go to measure CYA today and it is coming up as 0. I did a bench test with a gallon of water and measured out a miniscule amount of CYA to mix in at the correct ratio and the test does come out cloudy.
Can CYA burn off from an excessive amount of liquid shock? All the things I've read in the past say CYA only leaves when you replace pool water but I've only backwashed 2 or 3 times. Not nearly enough water exchanged to drop to 0.
Thoughts?
Thoughts?
