Is it possible to add small amounts of CYA to my pool without backwashing first?
background : I recently finished a SLAM - even though a salt pool, I approached it more as a non salt pool since the water was too cold for the SWG to be effective.
MY CYA levels were Very low but I started the slam anyway because the cya ordered online hadn’t arrived.
I Passed overnight test, Water is warm enough now for SWG to work and I need to bring CYA up a lot. Here are my levels currently.
TC - 6ppm (And falling)
CC - 0.5ppm
CYA - between 20-30
pH -between 7.8 and 8.2 ( my test kit doesn’t specify levels in between but it’s closer to the 8.2 color)
CH - 165ppm
my challenge is my water levels are too low to backwash my pool without refilling from a hose but my muni water has a high pH. (Over 8) I ALWAYS struggle with a high pH combined with low alkalinity. I’ve learned that I need to do my best to rely on rain to fill the pool and to operate the SWG at only 20-40 percent to keep the aeration down. Consequently I do have to supplement A bit with chlorine, especially when my cya is low. Currently I have a couple 3 inch tricolor pucks floating in the pool because I welcome the extra cya, that the pH will fall a little, as well as the supplement to swg chlorine. But it is very slow at raising CYA
I want to wait until decent rainfall before backwashing - but am wondering if it’s dangerous to add a very small level of cya in the meantime. Maybe just a couple ounces ? Also, is the cya from the pucks Dangerous if I haven’t backwashed? (I’m thinking it is real eased so slowly that it hopefully wouldn’t Be an issue)
Thanks!
CC - 0.5ppm
CYA - between 20-30
CH - 165ppm
Thanks!
