Hi All,
New pool owner here and thanks for this great site, which helped me a lot. I have a in ground non-swcg chlorine vinyl liner pool of about 67000 liters, and since the house was vacant for about 3 months before I moved in, no maintain during this time. Yet the water is pretty clear and blue, only some small residuals at the bottom which i vacuumed (but within a day or two, it came back i suspect it was algae)
1 week ago, for the first time I took the water to a pool store and the staff told me the CYA was too high without telling me the number, and told me to drain 2 feet of water by backwash. I did for about 1 feet and wanted ask for a second opinion and went for another store. The other store provide me the testing as below, where CYA was 150 but staff said it's fine since in their table ideal was 30-200, and only issue is TA and FC is too low; and asked me to buy something to raise TA (i bought some and then went to Costco bought 6 kg of baking soda trying to practice TFP method) and use what's the rest of my previous owner's triclor and shock:
CYA 151
TC:0.4
FC:0.4
PH: 7.3
Total Alkalinity 74
Adj. Total Alk:29
Cal. Hardness: 227
Unfortunately I followed the instruction to put 3 triclor and shocked it three days ago (now i learned it will further raise the CYA) but today i read the chart Pool School - Chlorine / CYA Chart which shows my pool should only have a CYA level of 30-50. Per pool calculator i need to drain about 60-80% of water to reach it. I understand this is the right way to do it. But since I will be on vacation for another month with no one at home and return in October. So I will either close it before i leave, or leave it with no maintain for a month and come back and close it. So my question is, should I replace the water and adjust all reading to ideal now before closing, or should I simply pour lots of bleach to make it reach about 14-20 FC for 150 CYA (although I know CYA 100+ is not reliable reading). Also, is it suggested for me to close at the end of August (still 25 C degree+), or leave it for a month putting lots of bleach/Triclor.
Thanks in advance.
CYA 151
TC:0.4
FC:0.4
PH: 7.3
Total Alkalinity 74
Adj. Total Alk:29
Cal. Hardness: 227
Thanks in advance.
